Logitech Harmony Smart Control Hub Light Bulb Replacement
    1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: step 1, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: step 1, image 2 of 2
      • Use a spudger to lift up one of the rubber pads on the bottom of the hub.
      • Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
      • Repeat for the second rubber pad.
      Ask FixBot
    2. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 2, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 2, image 2 of 2
      • Use a PH00 screwdriver bit to remove the four 6mm Phillips screws on the bottom of the device.
      Ask FixBot
    3. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 3, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 3, image 2 of 2
      • Use a spudger to separate the top and bottom pieces of the device.
      Ask FixBot
    4. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 4, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 4, image 2 of 2
      • Use the PH00 screwdriver bit to unscrew the three 4mm Phillips screws on the control board.
      Ask FixBot
    5. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 5, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 5, image 2 of 2
      • Place the end of the opening tool under the yellow corner of the circuit board as shown.
      • Gently push upward to pry the board from its housing.
      Ask FixBot
    6. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 6, image 1 of 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 6, image 2 of 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 6, image 3 of 3
      • Determine which of the five bulbs are defective.
      • Turn the board over to expose the bulb solder.
      • Using a soldering iron, remove the solder and bulb. Replace with a new bulb and re-solder.
      Ask FixBot
2 other people completed this guide.
Josh Hendricks
464 Reputation
4 Guides authored
IUPUI, Team 3-2, Harley Fall 2015 Member of IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 30
All Time: 911
