Up to 20% off select tools
Logitech Harmony Smart Control Battery Contact Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
88
All Time:
5,654
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
This guide requires soldering, for soldering guide click below.
Soldering Guide
    1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: step 1, image 1 of 2 Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: step 1, image 2 of 2
      • Use both thumbs to slide the grooved cover off of the remote
      • Once the cover is off, remove the battery.
      Ask FixBot
    2. Logitech Harmony Smart Control Battery Contact  Replacement: step 2, image 1 of 2 Logitech Harmony Smart Control Battery Contact  Replacement: step 2, image 2 of 2
      • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
      Ask FixBot
    3. Logitech Harmony Smart Control Battery Contact  Replacement: step 3, image 1 of 3 Logitech Harmony Smart Control Battery Contact  Replacement: step 3, image 2 of 3 Logitech Harmony Smart Control Battery Contact  Replacement: step 3, image 3 of 3
      • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
      Ask FixBot
    4. Logitech Harmony Smart Control Battery Contact  Replacement: step 4, image 1 of 2 Logitech Harmony Smart Control Battery Contact  Replacement: step 4, image 2 of 2
      • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
      • Slide the circuit board out from the housing .
      Ask FixBot
    5. Logitech Harmony Smart Control Battery Contact  Replacement: step 5, image 1 of 1
      • Locate the battery contacts on the circuit board.
      • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
      Ask FixBot
Author
with
Josh Hendricks
464 Reputation
4 Guides authored
IUPUI, Team 3-2, Harley Fall 2015 Member of IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Members
60 Guides authored
1 Guide Comment
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 88
All Time: 5,654
