Logitech Harmony Companion Remote Motherboard Replacement
Views: 8.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
130
All Time:
8,260
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The motherboard is a central part in the operation of your Companion remote. If your remote is not working after adjusting the settings and replacing the battery, you may need to replace the motherboard. All you need for this guide is a plastic opening tool and a Phillps #0 screwdriver.
Parts
Tools
    1. Logitech Harmony Companion Remote Motherboard Replacement, Remote Battery: step 1, image 1 of 1
      • Hold the remote with the Logitech label toward you.
      Ask FixBot
    2. Logitech Harmony Companion Remote Motherboard Replacement: step 2, image 1 of 1
      • Push the battery cover upward.
      Ask FixBot
    3. Logitech Harmony Companion Remote Motherboard Replacement: step 3, image 1 of 3 Logitech Harmony Companion Remote Motherboard Replacement: step 3, image 2 of 3 Logitech Harmony Companion Remote Motherboard Replacement: step 3, image 3 of 3
      • Use your finger to lift the battery out of the compartment.
      • When the battery has lifted, push it up to remove it.
      Ask FixBot
    1. Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: step 4, image 1 of 2 Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: step 4, image 2 of 2
      • Remove the two 5.0 mm Phillips #0 screws.
      Ask FixBot
    2. Logitech Harmony Companion Remote Motherboard Replacement: step 5, image 1 of 2 Logitech Harmony Companion Remote Motherboard Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to pry open the back cover of the remote.
      • It is recommended to have the point of the opening tool facing the back of the remote.
      • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
      • Pry the back cover off by sliding the plastic opening tool down each side.
      Ask FixBot
    3. Logitech Harmony Companion Remote Motherboard Replacement: step 6, image 1 of 2 Logitech Harmony Companion Remote Motherboard Replacement: step 6, image 2 of 2
      • Use the plastic opening tool to remove the motherboard.
      Ask FixBot
6 other people completed this guide.
Cassidy Wardlow
716 Reputation
4 Guides authored
USF Tampa, Team S1-G3, Nance Fall 2017 Member of USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Members
48 Guides authored
1 Guide Comment
Any source on that motherboard? I've got two dead buttons and replacement remotes are expensive and hard to come by.
Karl Wooster - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 130
All Time: 8,260
