Logitech Harmony 950 Motherboard Replacement
    1. Logitech Harmony 950 Motherboard Replacement, Battery: step 1, image 1 of 2 Logitech Harmony 950 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Make sure the remote control is powered off before starting.
      • Use the Opening Tool to open the port cover at the bottom of the remote control.
      • Bend the cover back to gain easy access to the screws.
      Ask FixBot
    2. Logitech Harmony 950 Motherboard Replacement: step 2, image 1 of 3 Logitech Harmony 950 Motherboard Replacement: step 2, image 2 of 3 Logitech Harmony 950 Motherboard Replacement: step 2, image 3 of 3
      • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
      • Pull the bottom cover off of the remote control.
      Ask FixBot
    3. Logitech Harmony 950 Motherboard Replacement: step 3, image 1 of 3 Logitech Harmony 950 Motherboard Replacement: step 3, image 2 of 3 Logitech Harmony 950 Motherboard Replacement: step 3, image 3 of 3
      • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
      • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
      Ask FixBot
    4. Logitech Harmony 950 Motherboard Replacement: step 4, image 1 of 3 Logitech Harmony 950 Motherboard Replacement: step 4, image 2 of 3 Logitech Harmony 950 Motherboard Replacement: step 4, image 3 of 3
      • Use the Opening Tool to lift the battery out of the case.
      • Gently pull the cable out of the socket to unplug the battery.
      • Be careful not to damage any part of the remote when pulling the cable out.
      Ask FixBot
    1. Logitech Harmony 950 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Logitech Harmony 950 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Logitech Harmony 950 Motherboard Replacement, Motherboard: step 5, image 3 of 3
      • Use the Phillips #0 screwdriver to remove the (3) three 6mm screws.
      • Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
      • You need to repeat this process for both sides of the remote.
      Ask FixBot
    2. Logitech Harmony 950 Motherboard Replacement: step 6, image 1 of 3 Logitech Harmony 950 Motherboard Replacement: step 6, image 2 of 3 Logitech Harmony 950 Motherboard Replacement: step 6, image 3 of 3
      Tool used on this step:
      $3.99
      Buy
      • Carefully remove the back cover and place it next to the remote. Be careful not to detach the wire during this process.
      • Use the angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
      Ask FixBot
    3. Logitech Harmony 950 Motherboard Replacement: step 7, image 1 of 3 Logitech Harmony 950 Motherboard Replacement: step 7, image 2 of 3 Logitech Harmony 950 Motherboard Replacement: step 7, image 3 of 3
      • Use the Phillips #0 screwdriver to remove the (5) five 6mm screws.
      • Be careful not to detach the pink wires when removing the gold charging conductors.
      Ask FixBot
    4. Logitech Harmony 950 Motherboard Replacement: step 8, image 1 of 3 Logitech Harmony 950 Motherboard Replacement: step 8, image 2 of 3 Logitech Harmony 950 Motherboard Replacement: step 8, image 3 of 3
      • Remove the black tape to access the cable underneath.
      • Use the Angled Tweezers to lift the black lock.
      • Slide the yellow cable to disconnect it from the circuit board.
      Ask FixBot
    5. Logitech Harmony 950 Motherboard Replacement: step 9, image 1 of 2 Logitech Harmony 950 Motherboard Replacement: step 9, image 2 of 2
      • Pull the circuit board off of the remote from the bottom, and lift up to detach it from the cover.
      Ask FixBot
2 other people completed this guide.
Blake Sanborn
601 Reputation
3 Guides authored
USF Tampa, Team S2-G2, Passmore Fall 2017 Member of USF Tampa, Team S2-G2, Passmore Fall 2017
USFT-PASSMORE-F17S2G2
4 Members
48 Guides authored
3 Guide Comments
How replace A Mitsubishi Remote Control
عبدالعزيز المناعي - Reply Share
How replace A Mitsubishi Remote Control ?
Thanks
Air conditioning
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 65
All Time: 4,481
