Logitech Harmony 950 Battery Replacement
    1. Logitech Harmony 950 Battery Replacement, Battery: step 1, image 1 of 2 Logitech Harmony 950 Battery Replacement, Battery: step 1, image 2 of 2
      • Make sure the remote control is powered off before starting.
      • Use the Opening Tool to open the port cover at the bottom of the remote control.
      • Bend the cover back to gain easy access to the screws.
      Ask FixBot
    2. Logitech Harmony 950 Battery Replacement: step 2, image 1 of 3 Logitech Harmony 950 Battery Replacement: step 2, image 2 of 3 Logitech Harmony 950 Battery Replacement: step 2, image 3 of 3
      • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
      • Pull the bottom cover off of the remote control.
      Ask FixBot
    3. Logitech Harmony 950 Battery Replacement: step 3, image 1 of 3 Logitech Harmony 950 Battery Replacement: step 3, image 2 of 3 Logitech Harmony 950 Battery Replacement: step 3, image 3 of 3
      • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
      • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
      Ask FixBot
    4. Logitech Harmony 950 Battery Replacement: step 4, image 1 of 3 Logitech Harmony 950 Battery Replacement: step 4, image 2 of 3 Logitech Harmony 950 Battery Replacement: step 4, image 3 of 3
      • Use the Opening Tool to lift the battery out of the case.
      • Gently pull the cable out of the socket to unplug the battery.
      • Be careful not to damage any part of the remote when pulling the cable out.
      Ask FixBot
10 other people completed this guide.
Blake Sanborn
601 Reputation
3 Guides authored
USF Tampa, Team S2-G2, Passmore Fall 2017 Member of USF Tampa, Team S2-G2, Passmore Fall 2017
USFT-PASSMORE-F17S2G2
4 Members
48 Guides authored
3 Guide Comments
And where to buy these batteries?
Rene A - Reply Share
Still no batteries for this unit? Maybe Amazon?
Dan - Reply Share
|Just checked, and batteries are available on Amazon from several vendors. Mine is on its last legs, so I have ordered one.
Mac Samildanach - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 100
All Time: 7,437
