Up to 20% off select tools
Logitech Harmony 650 Screen Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
107
All Time:
3,610
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
It is recommended that you have the iFixit ProTech toolkit and have already taken out the motherboard and taken apart the case.
    1. Logitech Harmony 650 Screen Replacement, Case: step 1, image 1 of 2 Logitech Harmony 650 Screen Replacement, Case: step 1, image 2 of 2
      • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
      Ask FixBot
    2. Logitech Harmony 650 Screen Replacement: step 2, image 1 of 1
      • Remove the batteries using the silver pull tab.
      Ask FixBot
    3. Logitech Harmony 650 Screen Replacement: step 3, image 1 of 1
      • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
      Ask FixBot
    4. Logitech Harmony 650 Screen Replacement: step 4, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
      Ask FixBot
    5. Logitech Harmony 650 Screen Replacement: step 5, image 1 of 1
      • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
      Ask FixBot
    6. Logitech Harmony 650 Screen Replacement: step 6, image 1 of 2 Logitech Harmony 650 Screen Replacement: step 6, image 2 of 2
      • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
      • The top led protector plastic cover will also be freed once back is removed.
      Ask FixBot
    7. Logitech Harmony 650 Screen Replacement: step 7, image 1 of 1
      • Remove the rear cover.
      Ask FixBot
    1. Logitech Harmony 650 Screen Replacement, Motherboard: step 8, image 1 of 2 Logitech Harmony 650 Screen Replacement, Motherboard: step 8, image 2 of 2
      • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
      Ask FixBot
    2. Logitech Harmony 650 Screen Replacement: step 9, image 1 of 1
      • Remove the motherboard by gently pulling it away from the case.
      Ask FixBot
    1. Logitech Harmony 650 Screen Replacement, Screen: step 10, image 1 of 2 Logitech Harmony 650 Screen Replacement, Screen: step 10, image 2 of 2
      • Remove the black rubber gasket that surrounds the screen from the top face of the motherboard.
      • The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
      Ask FixBot
    2. Logitech Harmony 650 Screen Replacement: step 11, image 1 of 1
      • Use a soldering iron to loosen the solder that connects the screen strip to the back of the motherboard. If it does not loosen easily then try using a soldering remover wick.
      • The soldering iron gets extremely hot use caution when using it around components.
      Ask FixBot
    3. Logitech Harmony 650 Screen Replacement: step 12, image 1 of 1
      Ask FixBot
    4. Logitech Harmony 650 Screen Replacement: step 13, image 1 of 1
      • Use a spudger or your hand to remove the screen from the motherboard. It is glued down.
      Ask FixBot
4 other people completed this guide.
Author
with
Connor Gallagher
1,036 Reputation
5 Guides authored
2 Guide Comments
Hey will beat buy honor a warrenty
antonioofficial - Reply Share
so where can i buy the screen!!!!
shortemperd Gotico - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 107
All Time: 3,610
