Tools
Introduction
Go to step 1 ↓This guide shows you how to begin the disassembly of the Logitech Harmony 650 Universal Remote. It is recommended that you have the iFixit ProTech Toolkit.
Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
Tool used on this step:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
5 other people completed this guide.
1 Guide Comment
Thanks for the fix. Now I can get on replacing the corroded battery contacts. Many thanks.
