Up to 20% off select tools
Logitech Harmony 650 Button Replacement
Views: 15K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
153
All Time:
15,267
Comments: 10
2 comments on steps, 8 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
It is recommended that you have the iFixit ProTech Tool Kit and have already taken out the Motherboard and removed the case.
    1. Logitech Harmony 650 Button Replacement, Case: step 1, image 1 of 2 Logitech Harmony 650 Button Replacement, Case: step 1, image 2 of 2
      • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
      Ask FixBot
    2. Logitech Harmony 650 Button Replacement: step 2, image 1 of 1
      • Remove the batteries using the silver pull tab.
      Ask FixBot
    3. Logitech Harmony 650 Button Replacement: step 3, image 1 of 1
      • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
      Ask FixBot
    4. Logitech Harmony 650 Button Replacement: step 4, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
      Ask FixBot
    5. Logitech Harmony 650 Button Replacement: step 5, image 1 of 1
      • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
      Ask FixBot
    6. Logitech Harmony 650 Button Replacement: step 6, image 1 of 2 Logitech Harmony 650 Button Replacement: step 6, image 2 of 2
      • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
      • The top led protector plastic cover will also be freed once back is removed.
      Ask FixBot
    7. Logitech Harmony 650 Button Replacement: step 7, image 1 of 1
      • Remove the rear cover.
      Ask FixBot
    1. Logitech Harmony 650 Button Replacement, Motherboard: step 8, image 1 of 2 Logitech Harmony 650 Button Replacement, Motherboard: step 8, image 2 of 2
      • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
      Ask FixBot
    2. Logitech Harmony 650 Button Replacement: step 9, image 1 of 1
      • Remove the motherboard by gently pulling it away from the case.
      Ask FixBot
    1. Logitech Harmony 650 Button Replacement, Button: step 10, image 1 of 1
      • Using a spudger, gently pry the bottom retaining place from the front case.
      Ask FixBot
    2. Logitech Harmony 650 Button Replacement: step 11, image 1 of 2 Logitech Harmony 650 Button Replacement: step 11, image 2 of 2
      • Peel away both the upper and lower sets of buttons using your fingers.
      Ask FixBot
15 other people completed this guide.
Author
with
Connor Gallagher
1,036 Reputation
5 Guides authored
8 Guide Comments
Good instructions. Where can I purchase new buttons???
Michael Freeman - Reply Share
Hello, I would recommend looking on eBay for a broken remote with a good membrane, also check craigslist or potentially amazon. A quick search for one and I couldn't find a membrane.
Austin K - Reply Share
I also am looking for a new button membrane, any ideas? gimmick73@hotmail.com
gimmick73 - Reply Share
Good advice. I bought a used one from ebay to replace the one I bought brand new from bestbuy and promptly broke the screen by dropping it on the kitchen floor. I plan on replacing the worn buttons on the working used replacement with the buttons from my broken one, and perhaps the case as well. Will let you know how it works out.
Jeremiah Behrens - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 153
All Time: 15,267
