Logitech Harmony 650 Battery Terminal Replacement
    1. Logitech Harmony 650 Battery Terminal Replacement, Case: step 1, image 1 of 2 Logitech Harmony 650 Battery Terminal Replacement, Case: step 1, image 2 of 2
      • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
      Ask FixBot
    2. Logitech Harmony 650 Battery Terminal Replacement: step 2, image 1 of 1
      • Remove the batteries using the silver pull tab.
      Ask FixBot
    3. Logitech Harmony 650 Battery Terminal Replacement: step 3, image 1 of 1
      • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
      Ask FixBot
    4. Logitech Harmony 650 Battery Terminal Replacement: step 4, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
      Ask FixBot
    5. Logitech Harmony 650 Battery Terminal Replacement: step 5, image 1 of 1
      • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
      Ask FixBot
    6. Logitech Harmony 650 Battery Terminal Replacement: step 6, image 1 of 2 Logitech Harmony 650 Battery Terminal Replacement: step 6, image 2 of 2
      • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
      • The top led protector plastic cover will also be freed once back is removed.
      Ask FixBot
    7. Logitech Harmony 650 Battery Terminal Replacement: step 7, image 1 of 1
      • Remove the rear cover.
      Ask FixBot
    1. Logitech Harmony 650 Battery Terminal Replacement, Battery Terminal: step 8, image 1 of 2 Logitech Harmony 650 Battery Terminal Replacement, Battery Terminal: step 8, image 2 of 2
      • Using the small end of a spudger, pry out the terminal from the interior of the case.
      Ask FixBot
    2. Logitech Harmony 650 Battery Terminal Replacement: step 9, image 1 of 1
      • Start from one side and work your way to the other side using the spudger.
      Ask FixBot
    3. Logitech Harmony 650 Battery Terminal Replacement: step 10, image 1 of 1
      • Remove the terminal.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 3,824
