Up to 20% off select tools
Logitech Gamepad F310 Disassembly
Views: 2.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
32
Past 30 Days:
149
All Time:
2,186
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This is a prerequisite guide for the disassembly of the case of the Logitech Gamepad F310. Disassembly of the case is an important part for making any replacement to the Gamepad.
    1. Logitech Gamepad F310 Disassembly, Case: step 1, image 1 of 2 Logitech Gamepad F310 Disassembly, Case: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
      Ask FixBot
    2. Logitech Gamepad F310 Disassembly: step 2, image 1 of 2 Logitech Gamepad F310 Disassembly: step 2, image 2 of 2
      • Press along the seams of the controller and gently pull the front and rear case apart.
      • If necessary, use an opening tool to help pry the front and rear case apart.
      • Make sure to open the controller with the front facing down so that the buttons do not fall out.
      Ask FixBot
    3. Logitech Gamepad F310 Disassembly: step 3, image 1 of 1
      • Separate the front and rear case.
      • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
      Ask FixBot
2 other people completed this guide.
Author
with
Lucas Stovall
428 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 149
All Time: 2,186
