Logitech Gamepad F310 D-Pad Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
97
All Time:
1,463
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace a damaged or malfunctioning D-Pad on a Logitech Gamepad F310. The D-Pad is a directional, plus sign shaped pad on the left side of the controller. It is used for precise movement and controls in most games.
Make sure to check to see if it is the D-Pad that is not working, and not a different control. Also try and restart your game, and unplug and plug back in your controller. This often times fixes the problem easily.
If your D-Pad is not working or is damaged, follow this guide to replace your D-Pad so you do not miss out on any important features of your games. Make sure the device is unplugged before beginning this guide.
No special tools or skills are required to complete this replacement.
Tools
    1. Logitech Gamepad F310 D-Pad Replacement, Case: step 1, image 1 of 2 Logitech Gamepad F310 D-Pad Replacement, Case: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
      Ask FixBot
    2. Logitech Gamepad F310 D-Pad Replacement: step 2, image 1 of 2 Logitech Gamepad F310 D-Pad Replacement: step 2, image 2 of 2
      • Press along the seams of the controller and gently pull the front and rear case apart.
      • If necessary, use an opening tool to help pry the front and rear case apart.
      • Make sure to open the controller with the front facing down so that the buttons do not fall out.
      Ask FixBot
    3. Logitech Gamepad F310 D-Pad Replacement: step 3, image 1 of 1
      • Separate the front and rear case.
      • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
      Ask FixBot
    1. Logitech Gamepad F310 D-Pad Replacement, D-Pad: step 4, image 1 of 3 Logitech Gamepad F310 D-Pad Replacement, D-Pad: step 4, image 2 of 3 Logitech Gamepad F310 D-Pad Replacement, D-Pad: step 4, image 3 of 3
      • Remove the silver 3 mm screw in the middle of the D-pad with a Phillips #1 screwdriver.
      • Remove the D-pad
      • There are 4 buttons that go in the four slots of the D-pad, a spring on one side, and the D-Pad on the other side.
      Ask FixBot
This is how to replace a D-Pad on a Logitech Gamepad F310. To reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 97
All Time: 1,463
