Tools
Introduction
Go to step 1 ↓Use this guide to replace a damaged or cracked controller case on your Logitech Gamepad F310. The controller case is what holds your controller together. That is reason to replace controller case.
Follow this guide in order to replace your Logitech Gamepad F310 controller case.
No special tools or skills required.
Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
Use a Phillips #1 screwdriver to remove:
Four 3 mm screws
One 5 mm screw
Gently lift the motherboard off of the back case and slide the cord out of the slot on top.
You have successfully taken the case off of your controller! Using the new case, follow these steps in reverse order to assemble your fixed controller.
