Up to 20% off select tools
Logitech Gamepad F310 Buttons Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
10
Past 7 Days:
42
Past 30 Days:
171
All Time:
2,091
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Have the buttons on your controller been through enough wear and tear? If so, here is the guide to help you with that. All you need is a Phillips #1 driver head, and a pry-tool. This guide will help you replace the buttons on your Logitech Gamepad F310.
The buttons is the input for controller to transmission's to pc for gaming purpose. The buttons are necessary for controller to play the gaming because it will not work if the buttons aren't working property. So that is reason to replacement for the buttons.
No special tools or skills are required.
    1. Logitech Gamepad F310 Buttons Replacement, Case: step 1, image 1 of 2 Logitech Gamepad F310 Buttons Replacement, Case: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
      Ask FixBot
    2. Logitech Gamepad F310 Buttons Replacement: step 2, image 1 of 2 Logitech Gamepad F310 Buttons Replacement: step 2, image 2 of 2
      • Press along the seams of the controller and gently pull the front and rear case apart.
      • If necessary, use an opening tool to help pry the front and rear case apart.
      • Make sure to open the controller with the front facing down so that the buttons do not fall out.
      Ask FixBot
    3. Logitech Gamepad F310 Buttons Replacement: step 3, image 1 of 1
      • Separate the front and rear case.
      • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
      Ask FixBot
    1. Logitech Gamepad F310 Buttons Replacement, Buttons: step 4, image 1 of 2 Logitech Gamepad F310 Buttons Replacement, Buttons: step 4, image 2 of 2
      • Remove any buttons that need replacement.
      • The buttons sit loosely in the front of the controller, so flipping the front over will drop all of the buttons out.
      Ask FixBot
You're all finished! To reassemble your device, follow these instructions in reverse order.
Author
with
Aaron Ajo Joseph
91 Reputation
1 Guide authored
1 Guide Comment
Any idea where I can get the d-pad rubber dome replacement part?
Anggoro Arif Junianto - Reply Share
Past 24 Hours: 10
Past 7 Days: 42
Past 30 Days: 171
All Time: 2,091
