Logitech Gamepad F310 Bumpers Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
107
All Time:
1,365
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
During this guide you will learn how to replace the bumpers on the Logitech Gamepad F310. The bumpers are the first set of buttons on the top part of the controller. They are small and rectangular.
The bumpers are special function for controller. So the bumpers are necessary tool for controller to play the functions for gaming purpose such as zooming, aiming, and etc.
No special tools or skills are required.
Tools
    1. Logitech Gamepad F310 Bumpers Replacement, Case: step 1, image 1 of 2 Logitech Gamepad F310 Bumpers Replacement, Case: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
      Ask FixBot
    2. Logitech Gamepad F310 Bumpers Replacement: step 2, image 1 of 2 Logitech Gamepad F310 Bumpers Replacement: step 2, image 2 of 2
      • Press along the seams of the controller and gently pull the front and rear case apart.
      • If necessary, use an opening tool to help pry the front and rear case apart.
      • Make sure to open the controller with the front facing down so that the buttons do not fall out.
      Ask FixBot
    3. Logitech Gamepad F310 Bumpers Replacement: step 3, image 1 of 1
      • Separate the front and rear case.
      • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
      Ask FixBot
    1. Logitech Gamepad F310 Bumpers Replacement, Bumpers: step 4, image 1 of 2 Logitech Gamepad F310 Bumpers Replacement, Bumpers: step 4, image 2 of 2
      • Grip the bumper and pull directly up to remove it.
      • Repeat for the other side if necessary.
      Ask FixBot
You're all finished! To reassemble your device, follow these instructions in reverse order.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 107
All Time: 1,365
