Logitech G920 Driving Force Steering Wheel D-Pad Replacement
  1. Logitech G920 Driving Force Steering Wheel D-Pad Replacement, Steering Wheel Motherboard: step 1, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
    Ask FixBot
  2. Logitech G920 Driving Force Steering Wheel D-Pad Replacement: step 2, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
    Ask FixBot
  3. Logitech G920 Driving Force Steering Wheel D-Pad Replacement: step 3, image 1 of 2 Logitech G920 Driving Force Steering Wheel D-Pad Replacement: step 3, image 2 of 2
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
    Ask FixBot
  4. Logitech G920 Driving Force Steering Wheel D-Pad Replacement: step 4, image 1 of 2 Logitech G920 Driving Force Steering Wheel D-Pad Replacement: step 4, image 2 of 2
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
    Ask FixBot
  5. Logitech G920 Driving Force Steering Wheel D-Pad Replacement: step 5, image 1 of 2 Logitech G920 Driving Force Steering Wheel D-Pad Replacement: step 5, image 2 of 2
    • Remove the eight 7.5 mm screws holding the steering wheel motherboard in place using a Phillips #0 screwdriver.
    • Remove the steering wheel motherboard.
    Ask FixBot
  6. Logitech G920 Driving Force Steering Wheel D-Pad Replacement, Steering Wheel D-Pad: step 6, image 1 of 2 Logitech G920 Driving Force Steering Wheel D-Pad Replacement, Steering Wheel D-Pad: step 6, image 2 of 2
    • Carefully remove the original D-Pad from the console.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 76
All Time: 1,558
