Logitech G920 Driving Force Motor Motherboard Replacement
    1. Logitech G920 Driving Force Motor Motherboard Replacement, Motor Motherboard: step 1, image 1 of 1
      • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
      • Only three of the five screws are visible from each side of the wheel due to the center unit.
      Ask FixBot
    2. Logitech G920 Driving Force Motor Motherboard Replacement: step 2, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
      Ask FixBot
    3. Logitech G920 Driving Force Motor Motherboard Replacement: step 3, image 1 of 2 Logitech G920 Driving Force Motor Motherboard Replacement: step 3, image 2 of 2
      • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
      • Remove the face plate from the steering wheel.
      Ask FixBot
    4. Logitech G920 Driving Force Motor Motherboard Replacement: step 4, image 1 of 2 Logitech G920 Driving Force Motor Motherboard Replacement: step 4, image 2 of 2
      • Remove the wheel from the main steering wheel console.
      • Ensure this is done carefully as to not damage the connection wire.
      Ask FixBot
    5. Logitech G920 Driving Force Motor Motherboard Replacement: step 5, image 1 of 2 Logitech G920 Driving Force Motor Motherboard Replacement: step 5, image 2 of 2
      • Remove the four 13.5 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    6. Logitech G920 Driving Force Motor Motherboard Replacement: step 6, image 1 of 2 Logitech G920 Driving Force Motor Motherboard Replacement: step 6, image 2 of 2
      • Remove the pedals from both sides of the wheel base.
      Ask FixBot
    7. Logitech G920 Driving Force Motor Motherboard Replacement: step 7, image 1 of 1
      • Remove the three 36 mm screws with a Phillips #2 screwdriver.
      Ask FixBot
    8. Logitech G920 Driving Force Motor Motherboard Replacement: step 8, image 1 of 3 Logitech G920 Driving Force Motor Motherboard Replacement: step 8, image 2 of 3 Logitech G920 Driving Force Motor Motherboard Replacement: step 8, image 3 of 3
      • Remove the wheel base from the motor box.
      Ask FixBot
    9. Logitech G920 Driving Force Motor Motherboard Replacement: step 9, image 1 of 1
      • Flip the motor box over.
      • Remove the twelve 12.2 mm screws with a Phillips #0 screwdriver.
      • Remove the two 11.5 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    10. Logitech G920 Driving Force Motor Motherboard Replacement: step 10, image 1 of 2 Logitech G920 Driving Force Motor Motherboard Replacement: step 10, image 2 of 2
      • Flip over the motor box once more.
      • Remove the motor box cover.
      Ask FixBot
    11. Logitech G920 Driving Force Motor Motherboard Replacement: step 11, image 1 of 3 Logitech G920 Driving Force Motor Motherboard Replacement: step 11, image 2 of 3 Logitech G920 Driving Force Motor Motherboard Replacement: step 11, image 3 of 3
      • Remove the four 5 mm screws with a Phillips #0 screwdriver.
      • Detach the wires connected to the motherboard.
      • Remove the motherboard from the motor box.
      Ask FixBot
6 other people completed this guide.
1 Guide Comment
Which wire is for the USB?
Davoyles lags - Reply Share
Past 24 Hours: 11
Past 7 Days: 60
Past 30 Days: 278
All Time: 8,379
