Up to 20% off select tools
Logitech G920 Driving Force Back Pedals Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
14
Past 7 Days:
51
Past 30 Days:
195
All Time:
4,179
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
This replacement guide will help you in replacing a faulty or broken back pedal on the Logitech G920 Driving Force. The following steps can be used for any of the three pedals that need to be replaced.
    1. Logitech G920 Driving Force Back Pedals Replacement, Back Pedals: step 1, image 1 of 1
      • Locate the pedal you need to replace.
      Ask FixBot
    2. Logitech G920 Driving Force Back Pedals Replacement: step 2, image 1 of 1
      • Use a Hex 2.5 screwdriver or Allen key to remove the two 30 mm center screws in the pedal.
      Ask FixBot
    3. Logitech G920 Driving Force Back Pedals Replacement: step 3, image 1 of 1
      • Remove the pedals from their stand.
      • Repeat steps 2-3 until all pedals needing replacement are removed.
      Ask FixBot
    4. Logitech G920 Driving Force Back Pedals Replacement: step 4, image 1 of 2 Logitech G920 Driving Force Back Pedals Replacement: step 4, image 2 of 2
      • Remove the 12 12mm screws from the bottom of the device using a Phillips #1 screwdriver.
      Ask FixBot
    5. Logitech G920 Driving Force Back Pedals Replacement: step 5, image 1 of 1
      • Remove the eight 12 mm screws from the bottom of the device with a Phillips #0 screwdriver.
      Ask FixBot
    6. Logitech G920 Driving Force Back Pedals Replacement: step 6, image 1 of 3 Logitech G920 Driving Force Back Pedals Replacement: step 6, image 2 of 3 Logitech G920 Driving Force Back Pedals Replacement: step 6, image 3 of 3
      • Push down the switch found in the hole at the top of the underside of the pedal board.
      • This opens the carpet-hold to access more screws.
      Ask FixBot
    7. Logitech G920 Driving Force Back Pedals Replacement: step 7, image 1 of 1
      • Remove the two 14 mm screws behind the carpet hold with a Phillips #0 screwdriver.
      Ask FixBot
    8. Logitech G920 Driving Force Back Pedals Replacement: step 8, image 1 of 2 Logitech G920 Driving Force Back Pedals Replacement: step 8, image 2 of 2
      • Remove the pedal back that matches the pedal front removed in step 3 .
      • This image is not upside down. When removing the back panel piece, the lettering on the inner pedal mechanism will appear this way.
      Ask FixBot
    9. Logitech G920 Driving Force Back Pedals Replacement: step 9, image 1 of 2 Logitech G920 Driving Force Back Pedals Replacement: step 9, image 2 of 2
      • Remove the washer and bolt at the top of the red piece on the pedal back.
      Ask FixBot
    10. Logitech G920 Driving Force Back Pedals Replacement: step 10, image 1 of 3 Logitech G920 Driving Force Back Pedals Replacement: step 10, image 2 of 3 Logitech G920 Driving Force Back Pedals Replacement: step 10, image 3 of 3
      • Remove the red piece, spring, and block within the pedal back.
      • Replace the necessary part.
      Ask FixBot
2 other people completed this guide.
Author
with
Aiden Muse
609 Reputation
3 Guides authored
2 Guide Comments
My set of pedals has an issue of continuously press break pedal, any idea what it can be? When I lift them into vertical position (holl base) it stops, but the again as horizontal (ready to be use) in the games like Forza EuroTruck Assets... etc, system behave as break pedal is press.
Olaf Tomczynski - Reply Share
Easyest fix would be to create a deadzone on the break pedal of like 5-10% so the sensor dosnt read it (this will only work if its not a issue with the sensor itself.
Other possibilitys could be the breakblock (personally recommend removing that anyways) inside becomming dislodged, dirt inside or at worst, the cable connected to the board might be not fully conected anymore and sending faulty signals.
Sarah Bentague - Reply Share
Past 24 Hours: 14
Past 7 Days: 51
Past 30 Days: 195
All Time: 4,179
