Logitech G915 TKL Volume Wheel Replacement
    1. Logitech G915 TKL Volume Wheel Replacement, Volume Wheel: step 1, image 1 of 2 Logitech G915 TKL Volume Wheel Replacement, Volume Wheel: step 1, image 2 of 2
      • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
      • Unscrew the two 2.5 mm #0 Phillips screws circled in the picture provided.
      • Remove the backplate by grabbing the notch to the right and pulling up.
      Ask FixBot
    2. Logitech G915 TKL Volume Wheel Replacement: step 2, image 1 of 2 Logitech G915 TKL Volume Wheel Replacement: step 2, image 2 of 2
      • Remove the foam strips shown in the picture provided.
      • Unscrew all the 2 mm #00 Phillips screws on the back of the keyboard circled in the picture provided.
      Ask FixBot
    3. Logitech G915 TKL Volume Wheel Replacement: step 3, image 1 of 1
      • Remove the keyboard's casing to reveal the motherboard.
      Ask FixBot
    4. Logitech G915 TKL Volume Wheel Replacement: step 4, image 1 of 2 Logitech G915 TKL Volume Wheel Replacement: step 4, image 2 of 2
      • Carefully remove the volume wheel from the device using your fingers.
      Ask FixBot
3 other people completed this guide.
Jahnyla Blakely-Wright
253 Reputation
1 Guide authored
2 Guide Comments
Where tf do you get the scroll bar thing from?
Bit Stream - Reply Share
Did you have any luck?
josesalomonfm - Reply Share
Past 24 Hours: 2
Past 7 Days: 39
Past 30 Days: 198
All Time: 5,911
