Logitech G915 TKL Keyswitch Replacement
    1. Logitech G915 TKL Keyswitch Replacement, Keyswitch: step 1, image 1 of 2 Logitech G915 TKL Keyswitch Replacement, Keyswitch: step 1, image 2 of 2
      • Remove all of the keycaps on the keyboard.
      • Unscrew the 2mm #00 Phillips screws circled in the picture provided.
      Ask FixBot
    2. Logitech G915 TKL Keyswitch Replacement: step 2, image 1 of 2 Logitech G915 TKL Keyswitch Replacement: step 2, image 2 of 2
      • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
      • Unscrew the two 2.5mm #0 Phillips screws circled in the picture provided.
      • Remove the backplate by grabbing the notch to the right and pulling up.
      Ask FixBot
    3. Logitech G915 TKL Keyswitch Replacement: step 3, image 1 of 2 Logitech G915 TKL Keyswitch Replacement: step 3, image 2 of 2
      • Remove the foam strips shown in the picture provided.
      • Unscrew all the 2mm #00 Phillips screws on the back of the keyboard circled in the picture provided.
      Ask FixBot
    4. Logitech G915 TKL Keyswitch Replacement: step 4, image 1 of 1
      • Remove the casing on the keyboard to reveal the motherboard.
      Ask FixBot
    5. Logitech G915 TKL Keyswitch Replacement: step 5, image 1 of 1
      • Find the corresponding soldering point for the keyswitch you wish to replace.
      Ask FixBot
    6. Logitech G915 TKL Keyswitch Replacement: step 6, image 1 of 1
      • Carefully heat the soldering wire.
      • Place the wire near the keyswitch's solder points so that it can be desoldered by the wire.
      Ask FixBot
      • Insert your new keyswitch in place of the old one.
      • Solder the new keyswitch into place.
      Ask FixBot
3 other people completed this guide.
Ethan Bedard
644 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 93
Past 30 Days: 458
All Time: 35,784
