Logitech G915 TKL Keycap Replacement
Views: 20K
View statistics:
Past 24 Hours:
8
Past 7 Days:
60
Past 30 Days:
273
All Time:
20,182
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to remove and replace a keycap on the Logitech G915 TKL keyboard. A keycap may need to be replaced if it's loose and not registering inputs properly, or simply broken for one reason or another. You may also need to remove or replace a keycap to fix other issues such as a broken keyswitch or double key presses.
No special tools or skills are required to complete this repair procedure.
    1. Logitech G915 TKL Keycap Replacement, Keycaps: step 1, image 1 of 3 Logitech G915 TKL Keycap Replacement, Keycaps: step 1, image 2 of 3 Logitech G915 TKL Keycap Replacement, Keycaps: step 1, image 3 of 3
      • Insert a flat tool underneath the top of the keycap or use your keycap puller to remove the keycap.
      • You may need to remove other keycaps to reach the keycap you wish to remove.
      Ask FixBot
    2. Logitech G915 TKL Keycap Replacement: step 2, image 1 of 2 Logitech G915 TKL Keycap Replacement: step 2, image 2 of 2
      • Place the new keycap on by sliding it back onto it's place.
      • Press down so the keycap locks into place.
      Ask FixBot
You've successfully removed and replaced a keycap on your Logitech G915 TKL keyboard.
Ethan Bedard
644 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 60
Past 30 Days: 273
All Time: 20,182
