Logitech G915 TKL G1-G8 Key Replacement
  1. Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: step 1, image 1 of 3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: step 1, image 2 of 3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: step 1, image 3 of 3
    • Remove all the keycaps.
    • While it can be done barehanded, use of a flat tool to remove the keycaps or use a keycap puller is recommended to prevent damage.
    Ask FixBot
  2. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the front: step 2, image 1 of 1
    • Unscrew the front 2mm #00 Phillips screws found here.
    Ask FixBot
  3. Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: step 3, image 1 of 3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: step 3, image 2 of 3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: step 3, image 3 of 3
    • Remove the battery.
    • This will require the removal of the back sticker and unscrewing the two 2.5mm #0 Phillips screws circled.
    Ask FixBot
  4. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the back: step 4, image 1 of 1
    • Remove the remaining 2mm #00 Phillips back screws.
    • 3 screws are hidden under the rubber rests of the keyboard.
    Ask FixBot
  5. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the motherboard: step 5, image 1 of 1
    • Remove the 2mm #00 Phillips motherboard screws.
    • The G1-G8 keys are held in place by the motherboard itself. Once the motherboard is detached, they can be easily removed and replaced by hand.
    Ask FixBot
3 other people completed this guide.
Brandon Souza
166 Reputation
1 Guide authored
5 Guide Comments
I can't find anywhere to buy a replacement key, can you point to a place where this is available?.
[deleted] - Reply Share
"Once the motherboard is detached, they can be easily removed and replaced by hand."
Except you can't! The motherboard and all the key switches are slightly overlapped. Unless you de-soldering all the switch, you can not change the G keys. Stupid solution from Logitech in a such expensive keyboard
János G. - Reply Share
Do i need soldering for my spacekey stabilizers since one fell out. Or is it an easy fix?
pannar1 pannar1 - Reply Share
Based on the images provided with the Guide I can't tell.
But you can create a question in the Forum so I, or someone else can help you there more precisely, you can upload close-up images there which will help helping you. :)
Felix - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 146
All Time: 6,887
