Logitech G915 TKL Feet Replacement
    1. Logitech G915 TKL Feet Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 3 Logitech G915 TKL Feet Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 3 Logitech G915 TKL Feet Replacement, Prepare your keyboard for disassembly: step 1, image 3 of 3
      • Slide the power switch on the top edge of the keyboard to the OFF (left) position.
      • A red indicator should be visible beneath the switch.
      • Unplug all cables from the keyboard.
      • Lay the keyboard down with the feet facing up on a clean work surface.
      • If your work surface might scratch the keyboard, place a soft towel under it.
      Ask FixBot
    1. Logitech G915 TKL Feet Replacement, Remove the feet: step 2, image 1 of 2 Logitech G915 TKL Feet Replacement, Remove the feet: step 2, image 2 of 2
      • Heat an iOpener and lay it on one of the feet for one minute.
      • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
      • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic body.
      Ask FixBot
    2. Logitech G915 TKL Feet Replacement: step 3, image 1 of 3 Logitech G915 TKL Feet Replacement: step 3, image 2 of 3 Logitech G915 TKL Feet Replacement: step 3, image 3 of 3
      • Insert the point of a spudger under an end of the foot.
      • Push the spudger underneath the foot and lift until you can grip it with your fingers.
      • The foot should come up without much force. If it feels stuck, apply more heat and try again.
      • Peel the foot up and remove it.
      • Repeat the previous two steps to remove the remaining feet.
      Ask FixBot
    3. Logitech G915 TKL Feet Replacement, Reassembly information: step 4, image 1 of 2 Logitech G915 TKL Feet Replacement, Reassembly information: step 4, image 2 of 2
      • To install a new foot:
      • Use the flat end of a spudger to scrape up and remove any chunks of adhesive from the foot recesses.
      • Remove the new feet from their backing and firmly press them into place.
      Ask FixBot
Spencer Day
201,049 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 54
All Time: 1,085
