Up to 20% off select tools
Logitech G910 Lights Replacement
Views: 8.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
146
All Time:
8,895
Comments: 7
3 comments on steps, 4 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the lights of your Logitech G910.
    1. Logitech G910 Lights Replacement, Lights: step 1, image 1 of 1
      • Unplug the keyboard from the computer.
      Ask FixBot
    2. Logitech G910 Lights Replacement: step 2, image 1 of 1
      • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
      Ask FixBot
    3. Logitech G910 Lights Replacement: step 3, image 1 of 1
      • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
      Ask FixBot
    4. Logitech G910 Lights Replacement, Lift the film: step 4, image 1 of 2 Logitech G910 Lights Replacement, Lift the film: step 4, image 2 of 2
      • Gently lift up the plastic film in the top right corner.
      Ask FixBot
5 other people completed this guide.
Author
with
Nasser
214 Reputation
1 Guide authored
4 Guide Comments
So what do I do after I take apart my keyboard?
CuddlyZebesian - Reply Share
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola - Reply Share
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire - Reply Share
This is just a guide to open the keyboard, not a light replacement. Finish or rename the guide.
Wesley Mason - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 146
All Time: 8,895
