Introduction
Go to step 1 ↓Use this guide to remove and replace the feet (also called skates or pads) on the bottom of a Logitech G903.
With sufficient heat, it’s possible to cleanly remove the feet, but you may need replacements if one rips or any adhesive is left behind.
Tools
Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
Slide the tip of an opening pick under an edge of the bottom mouse foot, making sure it goes under both the foot and its adhesive pad.
Gently slide the pick farther under the foot and lift until you can grip it with your fingers.
Use your fingers to peel up and remove the foot.
Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat it further.
Peel the adhesive off.
If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
Use a spudger to carefully scrape up and remove any remaining adhesive bits.
Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry (about 1–2 minutes).
Remove the feet from their backing and firmly press them into place.
Repeat the process to remove:
The top mouse foot
The two pentagonal mouse feet on the left and right side
The two small mouse feet in the center
