Introduction
Use this guide to replace a worn out or dead battery in your Logitech G733 wireless gaming headset.
If possible, complete this repair when your battery is below 10%—this is indicated when your headset's audio beeps every 15 minutes.
With one hand, firmly hold the right ear cup steady.
With your free hand, slowly pull the right ear pad away from the cup until it slides completely off its plastic lip.
With your free hand, put your fingers into the right ear pad and extend them outwards to stretch the pad.
Place the pad over the bottom of the cup so the fabric flap slides over the cup's plastic lip.
Hold the top of the pad firmly in place and thread the rest of the fabric flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
Use a Phillips screwdriver to remove the four 2.8 mm‑long screws securing the right speaker housing.
Gently remove the speaker housing and set it next to the ear cup, making sure the cable isn't strained.
Use a pair of angled tweezers to pull the battery connector straight out of its socket.
Tool used on this step:Tesa 61395 Tape$2.95
Use a spudger to slowly pry up the top edge of the battery until its adhesive separates.
Remove the battery.
If your replacement battery comes with adhesive pre-installed, remove the plastic liner and press the battery into place.
If your replacement battery doesn't come with adhesive pre-installed, use strips of double-sided tape to secure it in the recess.
For optimal performance, calibrate your newly installed battery after completing this guide.
11 other people completed this guide.
