Logitech G733 Volume Scroll Wheel Replacement
    1. Logitech G733 Volume Scroll Wheel Replacement, Volume Scroll Wheel: step 1, image 1 of 1
      • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Gently pull the left ear pad off, starting from the top.
      • Slide your finger around the edges until it releases completely.
      Ask FixBot
    2. Logitech G733 Volume Scroll Wheel Replacement: step 2, image 1 of 2 Logitech G733 Volume Scroll Wheel Replacement: step 2, image 2 of 2
      • Remove the four screws securing the speaker housing using the T4 Torx screwdriver.
      • Place these screws on the magnetic project mat so you don't lose them.
      Ask FixBot
    3. Logitech G733 Volume Scroll Wheel Replacement: step 3, image 1 of 3 Logitech G733 Volume Scroll Wheel Replacement: step 3, image 2 of 3 Logitech G733 Volume Scroll Wheel Replacement: step 3, image 3 of 3
      • The plastic cover should be lose now and you should be able to pull it back to reveal the circuit board inside.
      • Unscrew the screw on the bottom right-hand side of the headphone using the #000 Phillips Screwdriver.
      • Finally, use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
      • The scroll wheel may fly out when you pop the circuit board out.
      Ask FixBot
    4. Logitech G733 Volume Scroll Wheel Replacement: step 4, image 1 of 2 Logitech G733 Volume Scroll Wheel Replacement: step 4, image 2 of 2
      • Pull the volume wheel directly out.
      • Place the new scroll wheel in by lining up the two flat surfaces on the connectors.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 37
Past 30 Days: 147
All Time: 5,708
