Up to 20% off select tools
Logitech G733 Power Button Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
33
Past 30 Days:
131
All Time:
3,010
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you need to replace the power button on your Logitech G733 Wireless Headset, you can do so with this guide. Since getting to the power button requires taking off the circuit board, you can also access the scroll wheel using these same steps. For this guide, you will need a Phillips #000 screwdriver, a Torx T4 star-shaped bit, and a halberd spudger. The most difficult step is popping the plastic button off; make sure to do this step with care.
    1. Logitech G733 Power Button Replacement, Power Button: step 1, image 1 of 1
      • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Gently start to pull the left ear pad off, starting from the top.
      • Slide your finger around the edges until it releases completely.
      • Remove the ear pad.
      Ask FixBot
    2. Logitech G733 Power Button Replacement: step 2, image 1 of 2 Logitech G733 Power Button Replacement: step 2, image 2 of 2
      • Remove the four screws securing the speaker housing using a T4 Torx screwdriver.
      • Place these screws on the magnetic project mat so you don't lose them.
      Ask FixBot
    3. Logitech G733 Power Button Replacement: step 3, image 1 of 3 Logitech G733 Power Button Replacement: step 3, image 2 of 3 Logitech G733 Power Button Replacement: step 3, image 3 of 3
      • Gently lift off the speaker housing, with care not to strain the connected cable.
      • Remove the screw on the bottom right-hand side of the motherboard using a Phillips #000 screwdriver.
      • Use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
      • The scroll wheel may fly out when you pop the circuit board out.
      Ask FixBot
    4. Logitech G733 Power Button Replacement: step 4, image 1 of 2 Logitech G733 Power Button Replacement: step 4, image 2 of 2
      • Once the motherboard is loose, gently pull the wire out of its harness.
      • The wiring harness is glued, so be careful with it. It should pull out easily.
      Ask FixBot
    5. Logitech G733 Power Button Replacement: step 5, image 1 of 1
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Pop the power button out of its recess by pushing it through the side of the headphone with your finger.
      • Now use the hook end of the halberd spudger to pry the connecting piece of the power button off at the end furthest to the inside of the headphone.
      • This step is the most difficult, so be careful when prying.
      Ask FixBot
Author
with
Antonio Jensen
727 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 33
Past 30 Days: 131
All Time: 3,010
