Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Spudger4.9
Introduction
Go to step 1 ↓If your battery will no longer accept a charge and you need to replace the battery, you can do so with this guide. For this guide, you will need a T4 Torx screwdriver and a spudger. This is a popular repair and it is very easy to do!
Gently pull the right ear pad off, starting from the top.
Slide your finger around the edges until it releases completely.
Remove the ear pad.
To reassemble your device, please follow these instructions in reverse order.
6 other people completed this guide.
5 Guide Comments
This guide is great, but mentioning what kind of battery to purchase for the headset would make it infinitely better...
I fully agree
Its a 1.5 phillips on the right side. On the left side its a T5 screw not a T4. And you can easily remove the battery without a spudger. It came out with my bare hands.
took 2 mins to find battery info ..........................
Logi 533-000181
after a quick search i bought this and it fit:
https://he.aliexpress.com/item/100500538...
