Up to 20% off select tools
Logitech G710+ Disassembly
Views: 10K
View statistics:
Past 24 Hours:
3
Past 7 Days:
36
Past 30 Days:
130
All Time:
10,268
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
  • Spudger
    4.9
Tools
    1. Logitech G710+ Disassembly, Body: step 1, image 1 of 1
      • Remove 14 Phillips screws on the bottom of the kayboard.
      • Use a plastic tool to release the clips holding the case together.
      • There are two hidden clips above the left and right arrow keys.
      • Gently pry the two halves of the case apart.
      • Don't worry if any of the clips break, the screws will still hold the keyboard together once reassembled.
      Ask FixBot
    2. Logitech G710+ Disassembly, Mother board: step 2, image 1 of 3 Logitech G710+ Disassembly, Mother board: step 2, image 2 of 3 Logitech G710+ Disassembly, Mother board: step 2, image 3 of 3
      • Unscrew the one screw holding on the ground and pull out the cables.
      • A good way of getting the cables out is by putting a screwdriver right there and twisting.
      • Unscrew this screw
      Ask FixBot
    3. Logitech G710+ Disassembly, Scroll Wheel: step 3, image 1 of 1
      • The light thing comes out with a wiggle.
      • The scroll wheel on the other is harder because you have to melt or brake the supports off.
      • Then you have to get the wheel out which comes out with a very gentle wiggle.
      Ask FixBot
    4. Logitech G710+ Disassembly, Pads: step 4, image 1 of 1
      • You can then take off the little pads
      Ask FixBot
6 other people completed this guide.
Author
with
Jackson Poer
711 Reputation
2 Guides authored
3 Guide Comments
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
MaybeCrispyWaffles - Reply Share
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
wildcat_15au - Reply Share
Is there a video or illustration defining how the space bar works and is installed or removed? I cant figure out where the stabilizer bar actually sits
Rick Painter - Reply Share
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 130
All Time: 10,268
