Logitech G703 Lightspeed Scroll Wheel Replacement
    1. Logitech G703 Lightspeed Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 2 Logitech G703 Lightspeed Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 2
      • Flip the switch to OFF before proceeding.
      Ask FixBot
    2. Logitech G703 Lightspeed Scroll Wheel Replacement: step 2, image 1 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 2, image 2 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 2, image 3 of 3
      • Take the mouse skates off by using the flathead screwdriver.
      • If you intend to reuse the skates, it's recommended to warm them with a hairdryer to loosen the adhesive that secures them.
      Ask FixBot
    3. Logitech G703 Lightspeed Scroll Wheel Replacement: step 3, image 1 of 2 Logitech G703 Lightspeed Scroll Wheel Replacement: step 3, image 2 of 2
      • Unscrew the four 5.4 mm countersunk screws using the Phillips #00 screwdriver.
      Ask FixBot
    4. Logitech G703 Lightspeed Scroll Wheel Replacement: step 4, image 1 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 4, image 2 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 4, image 3 of 3
      • Pull apart the two halves of the mouse.
      • Be careful as you might break the tab to lock it back in place.
      Ask FixBot
    5. Logitech G703 Lightspeed Scroll Wheel Replacement: step 5, image 1 of 2 Logitech G703 Lightspeed Scroll Wheel Replacement: step 5, image 2 of 2
      • Unscrew the two 4.9 mm countersunk screws using the Phillips #00 screwdriver.
      Ask FixBot
    6. Logitech G703 Lightspeed Scroll Wheel Replacement: step 6, image 1 of 2 Logitech G703 Lightspeed Scroll Wheel Replacement: step 6, image 2 of 2
      • Unscrew the two 4.7 mm countersunk screws that secure the scroll wheel in using the Phillips #00 Screwdriver.
      Ask FixBot
    7. Logitech G703 Lightspeed Scroll Wheel Replacement: step 7, image 1 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 7, image 2 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 7, image 3 of 3
      • Remove the rubber piece protecting the scroll wheel.
      • Detach the scroll wheel from the white plastic piece and replace.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
11 other people completed this guide.
Nail Ninja Johnson
460 Reputation
1 Guide authored
1 Guide Comment
¿Hola, cual es la altura del switch de la rueda del mouse?
Lautaro Tello (Ignar) - Reply Share
Past 24 Hours: 17
Past 7 Days: 111
Past 30 Days: 446
All Time: 11,850
