Up to 20% off select tools
Logitech G700s Left and Right Mouse Button Disassembly
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
105
All Time:
3,272
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
How to remove the top left and right mouse button clicker for modding
    1. Logitech G700s Left and Right Mouse Button Disassembly, Top Case Replacement: step 1, image 1 of 1
      • Remove the batteries from the mouse.
      • Use a plastic opening tool to peel up the four mouse feet.
      Ask FixBot
    2. Logitech G700s Left and Right Mouse Button Disassembly: step 2, image 1 of 2 Logitech G700s Left and Right Mouse Button Disassembly: step 2, image 2 of 2
      • Remove the five 5.5mm Phillips #00 screws found underneath the mouse feet.
      Ask FixBot
    3. Logitech G700s Left and Right Mouse Button Disassembly: step 3, image 1 of 3 Logitech G700s Left and Right Mouse Button Disassembly: step 3, image 2 of 3 Logitech G700s Left and Right Mouse Button Disassembly: step 3, image 3 of 3
      • Pull the top of the mouse off of the bottom half.
      • There's a wire connecting the two halves.
      • Unplug the programmable buttons from the motherboard.
      • The white pin housing on the motherboard may come off while unplugging. In that case, use tool to pry between at location indicated to separate them and insert the housing back onto the motherboard.
      Ask FixBot
    1. Logitech G700s Left and Right Mouse Button Disassembly, Logitech G700s Left and Right Mouse Button Disassembly: step 4, image 1 of 2 Logitech G700s Left and Right Mouse Button Disassembly, Logitech G700s Left and Right Mouse Button Disassembly: step 4, image 2 of 2
      • Pop the right button piston off the ledge thingy
      • Then pop the left button piston off
      • It can take a bit of force to pop them off.
      Ask FixBot
    2. Logitech G700s Left and Right Mouse Button Disassembly: step 5, image 1 of 2 Logitech G700s Left and Right Mouse Button Disassembly: step 5, image 2 of 2
      • Remove the three Philips head screws holding the left and right button clicker in place
      Ask FixBot
    3. Logitech G700s Left and Right Mouse Button Disassembly: step 6, image 1 of 2 Logitech G700s Left and Right Mouse Button Disassembly: step 6, image 2 of 2
      • Remove the left and right button & G13 & scroll wheel lock assembly from the top shell assembly.
      • You can push on indicated locations to gain leverage
      Ask FixBot
Author
with
dennis97519
534 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 105
All Time: 3,272
