Up to 20% off select tools
Logitech G602 Motherboard Replacement
Views: 13K
View statistics:
Past 24 Hours:
4
Past 7 Days:
41
Past 30 Days:
166
All Time:
13,284
Comments: 6
1 comment on steps, 5 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to fully deconstruct the mouse and remove the green motherboard.
    1. Logitech G602 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Logitech G602 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Logitech G602 Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Use a spudger to pry off all 4 mouse feet from under the mouse.
      Ask FixBot
    2. Logitech G602 Motherboard Replacement: step 2, image 1 of 3 Logitech G602 Motherboard Replacement: step 2, image 2 of 3 Logitech G602 Motherboard Replacement: step 2, image 3 of 3
      • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from under the mouse feet.
      Ask FixBot
    3. Logitech G602 Motherboard Replacement: step 3, image 1 of 2 Logitech G602 Motherboard Replacement: step 3, image 2 of 2
      • Use the blue spudger to prop open the battery port.
      Ask FixBot
    4. Logitech G602 Motherboard Replacement: step 4, image 1 of 1
      • Remove the two AA batteries from the device.
      Ask FixBot
    5. Logitech G602 Motherboard Replacement: step 5, image 1 of 2 Logitech G602 Motherboard Replacement: step 5, image 2 of 2
      • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the mouse’s internal hardware.
      Ask FixBot
    6. Logitech G602 Motherboard Replacement: step 6, image 1 of 2 Logitech G602 Motherboard Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to grip and detach the white ribbon cable from the motherboard.
      Ask FixBot
    7. Logitech G602 Motherboard Replacement: step 7, image 1 of 1
      • Use pliers to detach the white plug from the motherboard.
      Ask FixBot
    8. Logitech G602 Motherboard Replacement: step 8, image 1 of 3 Logitech G602 Motherboard Replacement: step 8, image 2 of 3 Logitech G602 Motherboard Replacement: step 8, image 3 of 3
      • Use a Phillips #00 screwdriver to unscrew all 5 screws (3x5mm ) from the battery pack and motherboard.
      Ask FixBot
    9. Logitech G602 Motherboard Replacement: step 9, image 1 of 1
      • Remove the motherboard from the mouse.
      Ask FixBot
10 other people completed this guide.
Author
with
Jerico Morales
1,303 Reputation
4 Guides authored
5 Guide Comments
So can I buy a new motherboard? Where? I don’t see one available on this site.
Kat - Reply Share
Hi there Kat. Did you eventually find out where to get a new motherboard for your G602 mouse?
Luke Haasbroek - Reply Share
Jerico, I’ve got a problem with my g602, as the mouse is depleting new batteries energy. I put new batteries on, and they are immediately recognized as “low batteries” by the mouse system, flashing the led indicator as low battery as well. Any thoughts?
Cristian Pereverzieff - Reply Share
I'm having the same problem. Where you able to fix the problem?
Christopher Flynn - Reply Share
Completed successfully.
The hardest part was to find a spare mainboard.
Brendan - Reply Share
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 166
All Time: 13,284
