Logitech G533 Headphones doesnt work without USB cable
Views: 8.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
131
All Time:
8,296
Comments: 12
3 comments on steps, 9 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Community-Contributed Guide
Tools
      • If the power button lits up only if the USB cable is plugged in. You probably have a loosened power cable inside the left earcup.
      Ask FixBot
      • If your headphones still have a warranty, just return them to the shop.
      Ask FixBot
      • Before you start disassembling try all the guides on the official website to make sure your problem is not software-based.
      Ask FixBot
    1. Logitech G533 Headphones  doesnt work without USB cable: step 4, image 1 of 1
      • Take out the left earcup padding. Turn the right side of the earcup counterclockwise and unplug the battery.
      Ask FixBot
    2. Logitech G533 Headphones  doesnt work without USB cable: step 5, image 1 of 1
      • Unscrew 4 screws with Torx Security TR8 bit.
      Ask FixBot
    3. Logitech G533 Headphones  doesnt work without USB cable: step 6, image 1 of 1
      • Carefully move aside the speaker. There are very thin wires connected to it and the printed circuit.
      • Unscrew the 5 screws marked on the picture with Philips 0 bit.
      Ask FixBot
    4. Logitech G533 Headphones  doesnt work without USB cable: step 7, image 1 of 1
      • Loosen the screw on the picture and slide up the black top under it.
      Ask FixBot
    5. Logitech G533 Headphones  doesnt work without USB cable: step 8, image 1 of 1
      • Take out the middle frame piece.
      • You will need to push the speaker through the frame and take out the mic off the frame.
      Ask FixBot
    6. Logitech G533 Headphones  doesnt work without USB cable: step 9, image 1 of 1
      • Here you can see that the red power cable is loosened.
      Ask FixBot
    7. Logitech G533 Headphones  doesnt work without USB cable: step 10, image 1 of 1
      • It looks like the cables are not soldered to the printed circuit. Just glued to it.
      • Scrap off the glue. I used a scalpel.
      Ask FixBot
    8. Logitech G533 Headphones  doesnt work without USB cable: step 11, image 1 of 1
      • You can plug back the battery and hold the cable in its original place.
      • Switch the power button and the power light should turn on.
      • The light will turn on after 2 seconds. You will need to keep the cable in place the whole time.
      Ask FixBot
    9. Logitech G533 Headphones  doesnt work without USB cable: step 12, image 1 of 1
      • Now you have two options. You can glue the cable back in and risk it will get loosen again. Or solder it.
      • The weld on the picture was so crappy that the cable get off when I was assembling it back. And have to redo it.
      Ask FixBot
    10. Logitech G533 Headphones  doesnt work without USB cable: step 13, image 1 of 1
      • When I was assembling the headphones I noticed that the mic cable get partially naked. It happened because every time you move the mic leg the cable has contact with the insides of the earcup.
      • I recommend putting electrical tape over it or don't move the mic leg at all. Just use the mute button on the back of the left earcup.
      Ask FixBot
7 other people completed this guide.
Kobda
437 Reputation
1 Guide authored
9 Guide Comments
Hi, its possible to disassembly the mic to change the cable? Mine its cut in the middle and I need to replace
Sauron666 - Reply Share
Can you please link a picture of the problem? It will be easier for me to assess the problem.
Kobda - Reply Share
I have just taken apart the headphone because I have a similar problem, but I could not access the cable inside the microphone 'arm' without doing something that I thought might break it... Judging from the build quality inside I also think that it would be a pain in the a** to replace and fix it.
Miguel - Reply Share
yep, my mic cable also broke, didnt even try to fix it and rather bought external mic.
Kobda - Reply Share
Amazing guide, I was able to fix my headset to work with batteries again. Can't believe Logitech decided to glue the cables...
Daniel Barelli - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 131
All Time: 8,296
