Introduction
Go to step 1 ↓This guide shows how to remove and replace one or both of the ear pads (aka ear cushions, headset cushions, or headphone cushions) on your Logitech G522 Lightspeed headset.
Once the ear pads are removed, you can clean the speaker grille of any dirt, dust, or gunk that has built up.
With one hand, firmly hold an ear cup steady.
With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
Repeat the process to remove the other ear pad.
With your free hand, place the pad over the top of the cup, so the fabric flap slips over the cup's plastic lip.
Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
1 Guide Comment
Where can you buy the earpad replacement for the G522 Lightspeed Headset? Can't seem to find it anywhere! Thanks!
