Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓Use this guide to replace a worn out or dead battery in your Logitech G522 Lightspeed wireless headset.
The li-ion battery resides within the right ear cup.
It’s natural for batteries to lose capacity as they age. If your headset dies quickly and doesn't hold a charge, it may be time to replace the battery.
If possible, drain the headset's battery before you begin repairs. You'll hear an audio beep every 30 minutes when the battery's low.
With one hand, firmly hold the right ear cup steady.
With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
Remove the ear pad and set it aside for reassembly.
With one hand, firmly hold an ear cup steady.
With your free hand, place the pad over the top of the cup, so the fabric flap slips over the cup's plastic lip.
Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
Use a Phillips screwdriver to remove the two 7.2 mm‑long screws securing the right speaker housing.
Use your fingers to lift the bottom edge of the speaker housing.
Shift the speaker housing down as you lift it to free the top edge from the ear cup.
Align the top edge of the speaker housing with the two plastic tabs in the ear cup.
Once you've aligned the top edge, lay the speaker housing in place on top of the ear cup.
Use your fingernails to grip the edges of the speaker connector and slide it out of its socket.
Use your fingernails to grip the edges of the battery connector and slide it out of its socket.
If you're having trouble, try rocking the connector side-to-side to help loosen it.
Slowly press an opening pick under the edge of the battery, where the wires come out.
Apply pressure until the battery loosens from the ear cup.
Tool used on this step:Tesa 61395 Tape$2.95
If your replacement battery comes with adhesive pre-installed, remove the liner.
If your replacement battery doesn't come with adhesive pre-installed, install strips of double-sided tape onto the battery.
Center the battery in its recess.
Use your fingers to firmly press the battery to secure it in place.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to an R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
