Logitech G502 Proteus Core Cable Replacement
    1. Logitech G502 Proteus Core Cable Replacement, Cable: step 1, image 1 of 2 Logitech G502 Proteus Core Cable Replacement, Cable: step 1, image 2 of 2
      • Use a hairdryer to heat three mouse feet briefly.
      • Each mouse foot should take 7-8 seconds to heat up.
      Ask FixBot
    2. Logitech G502 Proteus Core Cable Replacement: step 2, image 1 of 3 Logitech G502 Proteus Core Cable Replacement: step 2, image 2 of 3 Logitech G502 Proteus Core Cable Replacement: step 2, image 3 of 3
      • Remove the mouse feet gently.
      • Avoid bending the mouse feet.
      Ask FixBot
    3. Logitech G502 Proteus Core Cable Replacement: step 3, image 1 of 2 Logitech G502 Proteus Core Cable Replacement: step 3, image 2 of 2
      • Use a screwdriver to remove the four 12.5 mm screws.
      Ask FixBot
    4. Logitech G502 Proteus Core Cable Replacement: step 4, image 1 of 3 Logitech G502 Proteus Core Cable Replacement: step 4, image 2 of 3 Logitech G502 Proteus Core Cable Replacement: step 4, image 3 of 3
      • Use a spudger to pry open the bottom case.
      • A screwdriver is shown in the photo but screwdrivers shouldn't be used for prying. They might accidentally damage internal components with a slip.
      Ask FixBot
    5. Logitech G502 Proteus Core Cable Replacement: step 5, image 1 of 2 Logitech G502 Proteus Core Cable Replacement: step 5, image 2 of 2
      • Raise the tabs to disconnect the ribbon.
      Ask FixBot
    6. Logitech G502 Proteus Core Cable Replacement: step 6, image 1 of 2 Logitech G502 Proteus Core Cable Replacement: step 6, image 2 of 2
      • Pull out the pin and remove the scroll wheel assembly.
      • Take out the two springs under the scroll wheel assembly.
      • Be careful when lifting the scroll wheel assembly. Do not lose the two specified springs.
      Ask FixBot
    7. Logitech G502 Proteus Core Cable Replacement: step 7, image 1 of 1
      • Unscrew five 12.5mm screws from the motherboard.
      Ask FixBot
    8. Logitech G502 Proteus Core Cable Replacement: step 8, image 1 of 3 Logitech G502 Proteus Core Cable Replacement: step 8, image 2 of 3 Logitech G502 Proteus Core Cable Replacement: step 8, image 3 of 3
      • Open the tabs lock on each side so you can disconnect the ribbon.
      • Disconnect the PCB from the mouse cable.
      Ask FixBot
    9. Logitech G502 Proteus Core Cable Replacement: step 9, image 1 of 3 Logitech G502 Proteus Core Cable Replacement: step 9, image 2 of 3 Logitech G502 Proteus Core Cable Replacement: step 9, image 3 of 3
      • Pull out the plastic piece.
      • Remove the mouse cable.
      Ask FixBot
9 other people completed this guide.
Sen
412 Reputation
1 Guide authored
2 Guide Comments
Let's say you're trying to fix your G502 without a legit logitech cord, you can just splice a usb cable and solder the correct wires to the pins. I did this twice and it works flawlessly
Black.Technician - Reply Share
If you are careful enough, you don't need to remove the side button ribbon.
Yueh Tse Chen - Reply Share
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 67
All Time: 10,902
