Up to 20% off select tools
Logitech G435 Ear Pads Replacement
Views: 6.2K
View statistics:
Past 24 Hours:
43
Past 7 Days:
241
Past 30 Days:
995
All Time:
6,150
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows how to remove and replace one or both of the ear pads (aka ear cushions, headset cushions, or headphone cushions) on your Logitech G435 headset.
Once the ear pads are removed, you can take the opportunity to clean the speaker grille of any dirt, dust, or gunk that has built up.
    1. Logitech G435 Ear Pads Replacement, Prepare the headset for disassembly: step 1, image 1 of 1
      • Power off the headset and unplug all cables.
      Ask FixBot
    2. Logitech G435 Ear Pads Replacement, Remove the ear pads: step 2, image 1 of 3 Logitech G435 Ear Pads Replacement, Remove the ear pads: step 2, image 2 of 3 Logitech G435 Ear Pads Replacement, Remove the ear pads: step 2, image 3 of 3
      • If you're replacing the headset battery, you only need to remove the left ear pad (the side containing the power button).
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Repeat the process to remove the other ear pad.
      Ask FixBot
    1. Logitech G435 Ear Pads Replacement, Install the ear pad: step 3, image 1 of 3 Logitech G435 Ear Pads Replacement, Install the ear pad: step 3, image 2 of 3 Logitech G435 Ear Pads Replacement, Install the ear pad: step 3, image 3 of 3
      • Installing an ear pad onto the cup can be tricky. Be patient and work slowly—it may take a couple tries.
      • Orient the ear pad so the wider part is at the top.
      • With your free hand, place the pad over the top of the cup, so the black fabric flap slips over the cup's plastic lip.
      • The ear pad has a clear plastic stiffener. This piece should not slip over the ear cup lip.
      Ask FixBot
    2. Logitech G435 Ear Pads Replacement: step 4, image 1 of 2 Logitech G435 Ear Pads Replacement: step 4, image 2 of 2
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      Ask FixBot
Author
with
Arthur Shi
354,406 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 43
Past 7 Days: 241
Past 30 Days: 995
All Time: 6,150
