Logitech G402 Left and Right Mouse Buttons Replacement
    1. Logitech G402 Left and Right Mouse Buttons Replacement, Left and Right Mouse Buttons: step 1, image 1 of 1
      • Remove the adhesive mouse skates from the bottom casing.
      Ask FixBot
    2. Logitech G402 Left and Right Mouse Buttons Replacement: step 2, image 1 of 3 Logitech G402 Left and Right Mouse Buttons Replacement: step 2, image 2 of 3 Logitech G402 Left and Right Mouse Buttons Replacement: step 2, image 3 of 3
      • Remove the five 1.2 mm screws using a Phillips #00 screwdriver from the bottom of the mouse.
      • Separate the top casing from the bottom.
      Ask FixBot
    3. Logitech G402 Left and Right Mouse Buttons Replacement: step 3, image 1 of 2 Logitech G402 Left and Right Mouse Buttons Replacement: step 3, image 2 of 2
      • Remove the two case screws using a Phillips #00 screwdriver.
      • Remove the single 1.2 mm screw from the middle of the circuit board using a Phillips #00 screwdriver.
      Ask FixBot
    4. Logitech G402 Left and Right Mouse Buttons Replacement: step 4, image 1 of 3 Logitech G402 Left and Right Mouse Buttons Replacement: step 4, image 2 of 3 Logitech G402 Left and Right Mouse Buttons Replacement: step 4, image 3 of 3
      • Remove the perpendicular circuit board containing the side buttons.
      • Remove the remaining 1.2 mm screws under the removed board and next to the mouse buttons using a Phillips #00 screwdriver.
      Ask FixBot
    5. Logitech G402 Left and Right Mouse Buttons Replacement: step 5, image 1 of 3 Logitech G402 Left and Right Mouse Buttons Replacement: step 5, image 2 of 3 Logitech G402 Left and Right Mouse Buttons Replacement: step 5, image 3 of 3
      • Pull back the plastic clip and lift the circuit board out of the bottom casing.
      Ask FixBot
    6. Logitech G402 Left and Right Mouse Buttons Replacement: step 6, image 1 of 2 Logitech G402 Left and Right Mouse Buttons Replacement: step 6, image 2 of 2
      • Separate the wire from the bottom casing by pulling the wire out.
      Ask FixBot
    7. Logitech G402 Left and Right Mouse Buttons Replacement: step 7, image 1 of 3 Logitech G402 Left and Right Mouse Buttons Replacement: step 7, image 2 of 3 Logitech G402 Left and Right Mouse Buttons Replacement: step 7, image 3 of 3
      • You can access the iFixit guide to soldering and desoldering here.
      • Please be cautious when using a soldering iron. Soldering irons can reach several hundreds of degrees in temperature and improper use may result in a burn.
      • Please perform soldering and desoldering in a very well ventilated space. Solder containing lead can potentially be toxic and be an irritant. Solder and desolder outside or in the presence of a fume hood or fume extractor.
      • The solder connections for the left and right buttons are labeled in the second picture.
      • The solder connections circled in red are for the left mouse button.
      • The solder connections circled in orange are for the left mouse button.
      Ask FixBot
    8. Logitech G402 Left and Right Mouse Buttons Replacement: step 8, image 1 of 2 Logitech G402 Left and Right Mouse Buttons Replacement: step 8, image 2 of 2
      • Solder the replacement button onto the circuit board.
      • Make sure the metal contacts are not bent and are touching the soldering contacts before soldering.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reassembly is complete, apply the replacement mouse skates.
Aaron C.
166 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 155
All Time: 3,956
