Up to 20% off select tools
Logitech G400s Scroll Wheel Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
135
All Time:
4,943
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
    1. Logitech G400s Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 1
      • Use a flathead screwdriver or your fingernail to remove the mouse feet.
      • Be careful to remove any film left by the mouse feet as well.
      Ask FixBot
    2. Logitech G400s Scroll Wheel Replacement: step 2, image 1 of 1
      • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
      Ask FixBot
    3. Logitech G400s Scroll Wheel Replacement: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
      Ask FixBot
    4. Logitech G400s Scroll Wheel Replacement: step 4, image 1 of 1
      • Gently pull the upper shell away from the bottom platform.
      Ask FixBot
    5. Logitech G400s Scroll Wheel Replacement: step 5, image 1 of 1
      • This is what the G400s will look like when the top shell is taken off.
      Ask FixBot
    6. Logitech G400s Scroll Wheel Replacement: step 6, image 1 of 1
      • Simply lift the scroll wheel out of the compartment it sits in. It can then be cleaned or replaced as desired.
      Ask FixBot
2 other people completed this guide.
Author
with
Max Evans
433 Reputation
3 Guides authored
USF Tampa, Team 16-7, Eyestone Fall 2016 Member of USF Tampa, Team 16-7, Eyestone Fall 2016
USFT-EYESTONE-F16S16G7
1 Member
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 135
All Time: 4,943
