Up to 20% off select tools
Logitech G400s Mouse skates Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
122
All Time:
2,676
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
If your Logitech G400s mouse (model 910-002836) feels sluggish, drags, or makes a scratchy sound when you move it across a mousepad, use this guide to replace the mouse skates (also called mouse feet or glide pads). The skates are the small PTFE pads stuck to the bottom of the mouse that let it slide smoothly across a surface. When they wear down or start peeling, you'll get friction, uneven movement, and poor tracking.
Before you start, flip the mouse over and check for debris stuck to the skates. If present, try removing it and see if that fixes the problem. If not, unplug the mouse from your computer before starting the repair.
    1. Logitech G400s Mouse skates Replacement, Mouse skates: step 1, image 1 of 1
      • Use a Jimmy to remove the mouse feet. Be careful to remove any film left by the mouse feet as well.
      Ask FixBot
    2. Logitech G400s Mouse skates Replacement: step 2, image 1 of 1
      • Remove the top mouse foot using a Jimmy and the same technique as in Step 1.
      Ask FixBot
    3. Logitech G400s Mouse skates Replacement: step 3, image 1 of 2 Logitech G400s Mouse skates Replacement: step 3, image 2 of 2
      • The smaller skate will go on the top portion of the mouse as shown.
      • The larger skate will go on the bottom portion of the mouse.
      • Take care to press both mouse skates firmly into place.
      Ask FixBot
Author
with
Max Evans
433 Reputation
3 Guides authored
USF Tampa, Team 16-7, Eyestone Fall 2016 Member of USF Tampa, Team 16-7, Eyestone Fall 2016
USFT-EYESTONE-F16S16G7
1 Member
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 122
All Time: 2,676
