Up to 20% off select tools
Logitech G400s Mouse Cable Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
117
All Time:
5,479
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Logitech G400s Mouse Cable Replacement, Mouse Cable: step 1, image 1 of 1
      • Use a Jimmy to remove the mouse feet.
      • Be careful to remove any film left by the mouse feet as well.
      Ask FixBot
    2. Logitech G400s Mouse Cable Replacement: step 2, image 1 of 1
      • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
      Ask FixBot
    3. Logitech G400s Mouse Cable Replacement: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
      Ask FixBot
    4. Logitech G400s Mouse Cable Replacement: step 4, image 1 of 1
      • Gently pull the upper shell away from the bottom platform.
      Ask FixBot
    5. Logitech G400s Mouse Cable Replacement: step 5, image 1 of 1
      • This is what the G400s will look like when the top shell is taken off.
      Ask FixBot
    6. Logitech G400s Mouse Cable Replacement: step 6, image 1 of 2 Logitech G400s Mouse Cable Replacement: step 6, image 2 of 2
      • Push the cable into its proper place inside the mouse shell.
      Ask FixBot
Author
with
Max Evans
433 Reputation
3 Guides authored
USF Tampa, Team 16-7, Eyestone Fall 2016 Member of USF Tampa, Team 16-7, Eyestone Fall 2016
USFT-EYESTONE-F16S16G7
1 Member
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 117
All Time: 5,479
