Up to 20% off select tools
Logitech G305 Scroll Wheel Replacement
Views: 32K
View statistics:
Past 24 Hours:
9
Past 7 Days:
146
Past 30 Days:
743
All Time:
32,443
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
By using this detailed guide, you can learn how to replace the Logitech G305 scroll wheel in 7 easy steps. Replacing a scroll wheel in a mouse is not as simple as it sounds, and takes a couple of tools to get the job done.
These tools are a crucial part of the process, and help to get it done. This repair is an essential part of larger mouse up-keep, and it helps to make sure the scroll wheel is working as it was meant to. By using this guide, you will understand how to successfully replace the scroll wheel for your Logitech G305 mouse using the tools below.
    1. Logitech G305 Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 2 Logitech G305 Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 2
      Tool used on this step:
      Flathead 1.5 mm Screwdriver
      $1.99
      Buy
      • Use a 1.5 mm flathead screwdriver to remove the four mouse skates from the bottom of the mouse.
      Ask FixBot
    2. Logitech G305 Scroll Wheel Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the four bottom case screws.
      • Caution, do not strip the head of the screws. These are not easily replaceable.
      Ask FixBot
    3. Logitech G305 Scroll Wheel Replacement: step 3, image 1 of 1
      • Remove the palm cover by simply sliding downwards. Remove the battery and the bluetooth usb.
      • Using a flat head screwdriver 1.5mm to not pry but to adjust the connector. By doing this it will allow you to open the inside.
      • Use caution when raising the outer shell—wires are still connected inside.
      Ask FixBot
    4. Logitech G305 Scroll Wheel Replacement: step 4, image 1 of 2 Logitech G305 Scroll Wheel Replacement: step 4, image 2 of 2
      • Using the flathead screwdriver 1.5mm you can undo the clip holding the wiring in place.
      Ask FixBot
    5. Logitech G305 Scroll Wheel Replacement: step 5, image 1 of 1
      • There is a metal spring that holds one side of the scroll wheel, remove the metal spring using a flathead screwdriver 1.5mm and lifting the scroll wheel.
      Ask FixBot
    6. Logitech G305 Scroll Wheel Replacement: step 6, image 1 of 1
      • Use a Phillips screw driver #00 to remove the four screws.
      • Be careful to not strip the screws, these can't be found at your local hardware store.
      Ask FixBot
    7. Logitech G305 Scroll Wheel Replacement: step 7, image 1 of 3 Logitech G305 Scroll Wheel Replacement: step 7, image 2 of 3 Logitech G305 Scroll Wheel Replacement: step 7, image 3 of 3
      • Using the Flathead screwdriver 1.5mm, disconnect the clip for the green and blue wire.
      • Remove the motherboard out of the casing.
      • The mouse wheel can only come out one way. Slide to the right to release mouse wheel.
      Ask FixBot
10 other people completed this guide.
Author
with
Nathan Rosales
393 Reputation
1 Guide authored
1 Guide Comment
Should you encounter issues with a malfunctioning scroll wheel, consider cleaning it using a can of compressed air and then applying a small amount of PTFE-based multi-use synthetic oil to the scroll wheel housing.
tomzo88 - Reply Share
Past 24 Hours: 9
Past 7 Days: 146
Past 30 Days: 743
All Time: 32,443
