Logitech G29 Driving Force Red Dial Replacement
  1. Logitech G29 Driving Force Red Dial Replacement, Red Dial: step 1, image 1 of 3 Logitech G29 Driving Force Red Dial Replacement, Red Dial: step 1, image 2 of 3 Logitech G29 Driving Force Red Dial Replacement, Red Dial: step 1, image 3 of 3
    • Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
    • Once the center cap is off, take the face of the wheel off the stand. Before totally taking off, disconnect the 7 pin white cable running into the base of the wheel and place base aside.
  2. Logitech G29 Driving Force Red Dial Replacement: step 2, image 1 of 1
    • Remove wire connecting the PCB to the base of the wheel.
  3. Logitech G29 Driving Force Red Dial Replacement: step 3, image 1 of 2 Logitech G29 Driving Force Red Dial Replacement: step 3, image 2 of 2
    • Take off the 7 (4.32mm diameter 8mm long) silver screws holding the PCB to the black housing on the wheel using bit Ph #0.
    • Move the PCB to the side to expose the back side of the red dial. Keep the remaining white cable connected to the secondary PCB.
    • Be careful not to lose the buttons and D-pad; once the PCB is removed they can easily be lost.
  4. Logitech G29 Driving Force Red Dial Replacement: step 4, image 1 of 2 Logitech G29 Driving Force Red Dial Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Press in the 3 red tabs located on the inside black housing of the dial. Using the medium sized tweezers, push the black center button out to reveal 3 small black screws.
    • Using the same bit as earlier (bit Ph #00), remove the three (3.32mm diameter 5mm length) screws to release the red dial.
Ben varner
400 Reputation
3 Guides authored
IUPUI, Team 1-3, Harley Fall 2023 Member of IUPUI, Team 1-3, Harley Fall 2023
IUPUI-HARLEY-F23S1G3
4 Members
4 Guides authored
1 Guide Comment
Where can the part be bought?
Jesu de Gannes - Reply Share
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 74
All Time: 2,595
