Up to 20% off select tools
Logitech G29 Driving Force Buttons Replacement
Views: 6.6K
View statistics:
Past 24 Hours:
8
Past 7 Days:
69
Past 30 Days:
373
All Time:
6,555
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide explains how to remove and replace the buttons on the Logitech G29 Driving Force wheel.
If the buttons are malfunctioning, disassembling the wheel may help identify the issue and allow for an effective repair—potentially saving the device from being discarded.
The procedure is straightforward and requires minimal disassembly.
    1. Logitech G29 Driving Force Buttons Replacement, Buttons: step 1, image 1 of 3 Logitech G29 Driving Force Buttons Replacement, Buttons: step 1, image 2 of 3 Logitech G29 Driving Force Buttons Replacement, Buttons: step 1, image 3 of 3
      • Remove the six black screws holding the Playstation center cap using the Hex 4.0 bit.
      • The outer diameter of these screws are 8.40mm with a length of 26mm.
      • The wheel is still attached the base via a bundled cable-connector.
      Ask FixBot
    2. Logitech G29 Driving Force Buttons Replacement: step 2, image 1 of 3 Logitech G29 Driving Force Buttons Replacement: step 2, image 2 of 3 Logitech G29 Driving Force Buttons Replacement: step 2, image 3 of 3
      • Gently lift the faceplate and wheel off the stand.
      • Pull the white 7-pin cable connector from the wheel PCB.
      • Use a spudger or plastic opening tool to help free the connector at its base. Do not pull on the wires.
      Ask FixBot
    3. Logitech G29 Driving Force Buttons Replacement: step 3, image 1 of 2 Logitech G29 Driving Force Buttons Replacement: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the seven 8 mm silver screws that secure the main wheel PCB.
      • Use a Phillips #00 screwdriver to remove the single 5 mm screw from the Share/Options/PlayStation button PCB.
      Ask FixBot
    4. Logitech G29 Driving Force Buttons Replacement: step 4, image 1 of 3 Logitech G29 Driving Force Buttons Replacement: step 4, image 2 of 3 Logitech G29 Driving Force Buttons Replacement: step 4, image 3 of 3
      Tool used on this step:
      $3.99
      Buy
      • Once the PCB is out, the triangle, square, circle, x button will be exposed. Use the angled tweezers to remove all four buttons.
      • These buttons are keyed to where only a certain key will fit in a certain spot.
      Ask FixBot
    5. Logitech G29 Driving Force Buttons Replacement: step 5, image 1 of 1
      • Once the PCB is out, the D-PAD will fall out as well. Use the angled tweezers to remove the D-PAD.
      • This is also keyed to where it can only fit in a certain direction.
      Ask FixBot
    6. Logitech G29 Driving Force Buttons Replacement: step 6, image 1 of 3 Logitech G29 Driving Force Buttons Replacement: step 6, image 2 of 3 Logitech G29 Driving Force Buttons Replacement: step 6, image 3 of 3
      • Remove the four black 5 mm screws holding the four buttons in place using a Phillips #00 screwdriver. These are located directly under the buttons.
      • The whole housing is not required to come out since only the blue buttons need to come out. Once the screws are removed the buttons will fall out.
      Ask FixBot
    7. Logitech G29 Driving Force Buttons Replacement: step 7, image 1 of 1
      • Remove the four black screws holding the four buttons in place using a Phillips #00 screwdriver. These are located directly under the buttons. The whole housing is not required to come out since only the blue buttons need to come out. Once the screws are removed the buttons will fall out.
      Ask FixBot
Author
with
Ben varner
400 Reputation
3 Guides authored
IUPUI, Team 1-3, Harley Fall 2023 Member of IUPUI, Team 1-3, Harley Fall 2023
IUPUI-HARLEY-F23S1G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 69
Past 30 Days: 373
All Time: 6,555
