Up to 20% off select tools
Logitech G27 Pedal Spring Replacement
Views: 24K
View statistics:
Past 24 Hours:
8
Past 7 Days:
55
Past 30 Days:
249
All Time:
24,046
Comments: 6
6 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If the pedals on your G27 aren't pressing down correctly, or if they just don't feel comfortable under your feet, you will want to replace the springs in the pedals. This isn't a hard replacement to do, all you need is a screwdriver.
    1. Logitech G27 Pedal Spring Replacement, Pedal Spring: step 1, image 1 of 1
      • Remove two screws from each pedal with a 2.5mm allen wrench.
      • The left two pedals have 30 mm screws and the right-most pedal has 16.3 mm screws.
      • Once these screws are off, take off the front faces on each pedal, they should be very easy to remove.
      Ask FixBot
    2. Logitech G27 Pedal Spring Replacement: step 2, image 1 of 2 Logitech G27 Pedal Spring Replacement: step 2, image 2 of 2
      • Flip over the device. Now remove fourteen 15.8 mm screws from the underside of the pedal assembly with a Phillips #1 screwdriver.
      • There are two of these screws under the carpet grip, make sure you don't miss those!
      • When finished, flip over the device again so that it's in its original position.
      Ask FixBot
    3. Logitech G27 Pedal Spring Replacement: step 3, image 1 of 3 Logitech G27 Pedal Spring Replacement: step 3, image 2 of 3 Logitech G27 Pedal Spring Replacement: step 3, image 3 of 3
      • Lift the top cover of the device from the front, don't completely remove it yet though, because there are still wires connecting both halves. (NEED PICTURE)
      • Behind the left-most pedal, there are two 7.4mm screws attaching a wire to the top cover. Remove these with a Phillips #1 screwdriver and release the wires.
      • Once the wires are no longer connected to the top cover, remove the cover completely.
      Ask FixBot
    4. Logitech G27 Pedal Spring Replacement: step 4, image 1 of 2 Logitech G27 Pedal Spring Replacement: step 4, image 2 of 2
      • Simultaneously remove the 10mm screws connecting the pedal to the red piston behind it.
      • This will take two 2.5mm allen wrenches, one for each side of the screw.
      • Once removed, the piston can rotate free of the pedal.
      Ask FixBot
    5. Logitech G27 Pedal Spring Replacement: step 5, image 1 of 1
      • Flip the piston away from the pedal and remove the top half of it. The spring should now be visible. (NEED PICTURE)
      • Take out the spring, and replace it with a new one.
      • Repeat steps four and five for each pedal that needs a spring replaced.
      Ask FixBot
10 other people completed this guide.
Author
with
Grant Blake
1,785 Reputation
2 Guides authored
Cal Poly, Team 15-4, Amido Spring 2015 Member of Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 Members
72 Guides authored
6 Guide Comments
Is it possible to replace / renew the potentiometers used for gas / brake?
Dave Pawson - Reply Share
I replaced the springs and reassembled in reverse order. However, my wheel will no longer power on. Any idea where I would have lost power? Thank you.
matthew.liam.gleason - Reply Share
What size is the cluch spring
isaacjohnson138 - Reply Share
6cm length
2cm diameter
hermimaier - Reply Share
Past 24 Hours: 8
Past 7 Days: 55
Past 30 Days: 249
All Time: 24,046
