Tools
Introduction
Go to step 1 ↓If the C-Clamps on your Logitech G27 break, you will need to replace them before using the steering wheel again. This is a little bit of a pain to do, because the C-Clamps are fully inside the device case. To replace them, you will just need to remove a few screws.
Remove the six gray 25mm hex screws with a 4mm allen wrench.
Carefully lift up the wheel, but do not disconnect it from the rest of the device.
24 other people completed this guide.
15 Guide Comments
I also need to find a place to buy replacement C-clamps from
