Up to 20% off select tools
Logitech G1 Optical Mouse Scroll Wheel Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
29
Past 30 Days:
147
All Time:
2,891
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the scroll wheel in a Logitech G1 optical mouse.
Sometimes the scroll wheel does not work when using the mouse. This guide not only shows you how to replace the mouse scroll wheel but also how to clean it.
    1. Logitech G1 Optical Mouse Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 1
      • Remove one screw at the bottom of the mouse.
      Ask FixBot
    2. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 2, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 2, image 2 of 2
      • Pull the top of the mouse lid gently to separate it from the rest of the mouse.
      • Potential for device damage: The lid and the body are connected with a wire, so separate them gently.
      Ask FixBot
    3. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 3, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 3, image 2 of 2
      • Pull the white connector from the circuit board.
      • Be sure the two small holes in the connector are positioned at the top when reassembling.
      Ask FixBot
    4. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 4, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 4, image 2 of 2
      • Carefully pull the scroll wheel up.
      • The long parts of the spring should be in the southeast and southwest directions when reassembling.
      Ask FixBot
    5. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 5, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 5, image 2 of 2
      • Carefully remove the two Phillips #0 screws.
      Ask FixBot
    6. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 6, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 6, image 2 of 2
      • Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
      • Potential for device damage: Do not use water or an iron brush to clean it.
      Ask FixBot
    7. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 7, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 7, image 2 of 2
      • Place the new scroll wheel into the mouse.
      Ask FixBot
    8. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 8, image 1 of 1
      • The spring should be inserted into a small groove.
      • The spring can be inserted after combining the mouse body.
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
wooseok yang
358 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 147
All Time: 2,891
