Logitech G X56 HOTAS Throttle Switch Board Replacement
  1. Logitech G X56 HOTAS Throttle Switch Board Replacement, Label Plate: step 1, image 1 of 2 Logitech G X56 HOTAS Throttle Switch Board Replacement, Label Plate: step 1, image 2 of 2
    • Remove the eight 8.6 mm long 1.5 mm hex screws from the label plate.
    Ask FixBot
  2. Logitech G X56 HOTAS Throttle Switch Board Replacement: step 2, image 1 of 1
    • Use an opening tool to pry off the mode switch knob.
    Ask FixBot
  3. Logitech G X56 HOTAS Throttle Switch Board Replacement: step 3, image 1 of 3 Logitech G X56 HOTAS Throttle Switch Board Replacement: step 3, image 2 of 3 Logitech G X56 HOTAS Throttle Switch Board Replacement: step 3, image 3 of 3
    • Remove the eight 12.5 mm long Phillips #1 screws from the underside of the label plate.
    • These screws are plastic! Be very careful when applying force.
    Ask FixBot
  4. Logitech G X56 HOTAS Throttle Switch Board Replacement: step 4, image 1 of 2 Logitech G X56 HOTAS Throttle Switch Board Replacement: step 4, image 2 of 2
    • Place the throttle right side up again, using the bottom panel as a coaster.
    • Gently pry the label plate from the body of the throttle.
    Ask FixBot
  5. Logitech G X56 HOTAS Throttle Switch Board Replacement, Switch Board: step 5, image 1 of 2 Logitech G X56 HOTAS Throttle Switch Board Replacement, Switch Board: step 5, image 2 of 2
    • Remove the 14 mm nuts at the base of the switches.
    Ask FixBot
  6. Logitech G X56 HOTAS Throttle Switch Board Replacement: step 6, image 1 of 1
    • Disconnect the connectors and de-solder the one black wire.
    Ask FixBot
  7. Logitech G X56 HOTAS Throttle Switch Board Replacement: step 7, image 1 of 1
    • Remove and replace the toggle switch daughterboard.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 304
