Logitech G X56 HOTAS Throttle Potentiometer Assembly Replacement
  1. Logitech G X56 HOTAS Throttle Potentiometer Assembly Replacement, Bottom Panel: step 1, image 1 of 1
    • Place the throttle upside down with the bottom panel facing up.
    Ask FixBot
  2. Logitech G X56 HOTAS Throttle Potentiometer Assembly Replacement: step 2, image 1 of 2 Logitech G X56 HOTAS Throttle Potentiometer Assembly Replacement: step 2, image 2 of 2
    • Remove the fifteen 13.6 mm Phillips #1 screws that secure the bottom panel to the base plate.
    Ask FixBot
  3. Logitech G X56 HOTAS Throttle Potentiometer Assembly Replacement: step 3, image 1 of 2 Logitech G X56 HOTAS Throttle Potentiometer Assembly Replacement: step 3, image 2 of 2
    • Remove the bottom panel by lifting straight up.
    Ask FixBot
  4. Logitech G X56 HOTAS Throttle Potentiometer Assembly Replacement, Potentiometer: step 4, image 1 of 1
    • Disconnect the motherboard wire bundles leading to the potentiometer.
    Ask FixBot
  5. Logitech G X56 HOTAS Throttle Potentiometer Assembly Replacement: step 5, image 1 of 1
    • Remove the two 9.4 mm Phillips #0 screws that secure the potentiometer.
    Ask FixBot
  6. Logitech G X56 HOTAS Throttle Potentiometer Assembly Replacement: step 6, image 1 of 1
    • Lift the potentiometer assembly up to remove it.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 54
All Time: 475
