Logitech G X56 HOTAS Throttle Motherboard Replacement
  1. Logitech G X56 HOTAS Throttle Motherboard Replacement, Bottom Panel: step 1, image 1 of 1
    • Place the throttle upside down with the bottom panel facing up.
    Ask FixBot
  2. Logitech G X56 HOTAS Throttle Motherboard Replacement: step 2, image 1 of 2 Logitech G X56 HOTAS Throttle Motherboard Replacement: step 2, image 2 of 2
    • Remove the fifteen 13.6 mm Phillips #1 screws that secure the bottom panel to the base plate.
    Ask FixBot
  3. Logitech G X56 HOTAS Throttle Motherboard Replacement: step 3, image 1 of 2 Logitech G X56 HOTAS Throttle Motherboard Replacement: step 3, image 2 of 2
    • Remove the bottom panel by lifting straight up.
    Ask FixBot
  4. Logitech G X56 HOTAS Throttle Motherboard Replacement, Motherboard: step 4, image 1 of 2 Logitech G X56 HOTAS Throttle Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Optional: Take a picture or mark each connector as you remove them for ease of reassembly.
    • Disconnect all of the motherboard connectors by pulling them straight up and out of their sockets.
    Ask FixBot
  5. Logitech G X56 HOTAS Throttle Motherboard Replacement: step 5, image 1 of 2 Logitech G X56 HOTAS Throttle Motherboard Replacement: step 5, image 2 of 2
    • Remove the four 11.6 mm-long Phillips #0 screws that secure the motherboard.
    Ask FixBot
  6. Logitech G X56 HOTAS Throttle Motherboard Replacement: step 6, image 1 of 1
    • Lift the motherboard from the base plate shell, carefully making sure to keep the USB power cable unstrained.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 452
